yn_02
Jan 16, 2023Aspirant
RAX50 no internet connection
So my device(RAX50) worked fine for the first 3 months or so, but then it failed to work occasionally. Now that after 5 months of using it, it rarely works. All light indicators look fine, routerlogi...
yn_02
Hi Michael,
Thanks for your reply.
The firmware version is V1.0.12.120
I use an NBN box and it should act as a modem (not too sure but probably it's an Australian thing?)
And yes the router has a set of LAN ports on the back.
Symptoms I see: around half an hour ago I can visit Youtube without a problem, but I can't visit other sites including Netflix and Google. And now I can't even visit Youtube. That happens before but overall I don't have internet most of the time. Since I can't identify a pattern, I called it 'rarely works'.
michaelkenward
Jan 16, 2023Guru - Experienced User
Ah, the dreaded NBN. There is no such thing as NBN technology. It just means Aussie Internet. It comes in different shapes and sizes.
This hints at a modem/router.
What make and model is it?
The sort of symptoms you see could well be down to this clash of routers, with the pair of them fighting over who directs the traffic on your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Some Internet service providers supply modem/routers that won't work in bridge mode. There may be ways to get the modem/router to cooperate. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
