carp2112's avatar
carp2112
Follower
Jan 13, 2021
rax50 Printer does not work now
I have a HP laserjet 4050TN printer that worked fine with my TP-Link Archer A7. But stopped working when I setup and its plugged in and not even recognized? Does anyone have a solution? Thanks
My Model is a nighthawk RAX50
Thanks,
Peter
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Peter,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
