iwantseth's avatar
iwantseth
Initiate
Jan 30, 2025
RAX50 remote management
Have RAX50 - stock firmware, updated to V1.0.16.132_2.0.92 I want to manage it remotely.  I don't see a remote management option. Is the only way to do this is to enable VPN access?
  • FURRYe38's avatar
    NG removed web page remote access from there routers a few years ago. Only remote access is with the Nighhawk app and it has limited features.
    You'll have to check out OpenWRT or DD-WRT to see if they support this model router.
    Good Luck.
