anthonyng5p
Jan 14, 2021Apprentice
RAX50 Router Just Froze and Stopped Routing
I experience a problem with my RAX50 router. The router "just stopped being reachable and routing". This symptom is that I could not reach the admin interface of the device on 192.168.1.1, and that t...
Jan 14, 2021Guru - Experienced User
So you understand you have a double nat but then complain because of issues with dhcp and routing?
Have you tried the RAX in access point mode to fix the double nat?
- anthonyng5pJan 14, 2021Apprentice
I can do that. However, your comment doesn't really make sense given the symptoms. The router works perfectly fine in its configuration with double NAT. We are talking about the RAX50 becoming non-responsive to IP connectivity and routing, all of a sudden and intermittently. If the explanation is that there is a defect in the software which causes the device to exhibit this symptom, and it is tied to double-NAT, then sure. I would change the configuraiton. However, I am not "complaining about routing". I am remarking that the device ceases routing and being reachable intermittently.
