Mywifi123's avatar
Mar 13, 2023
RAX50 started dropping connection recently
Hi,
Nothing has changed with my Cox modem or set up.  But recently my Netgear router has begun losing connection.  The 2.4 and 5g lights on the router will go out and devices can't connect to it.  I will have to unplug power to the router, or turn it off to regain connection, only to have the same thing happen again, maybe several hours later or a day later.  Of course my support and hardware warranty expired expired in June of 2021.  The router firmware is up to date.  Not sure if should pay Netgear for support to troubleshoot.  (I firmly don not believe in this business model to charge for assistance, especially since I paid good money for this router)  Or should I just move on?  Thanks for any help.
Earl
  • plemans's avatar
    What actual firmware number are you on?
    Did you try a factory reset and reinstall?
    or try downgrading the firmware a version (in case its an upgrade that caused the issues)
    Do wired devices drop or just wireless?
    What modem/gateway is it connected to?
    • Mywifi123's avatar
      Mywifi123
      Guide
      Cox modem is :
      Panoramic WIFI Gateway
      Brand: TECHNICOLOR
      Model: CGM4331COM
      As I said, firmware is up to date:
      v1.0.12.120  according to the phone app.
      A Sony TV and a DIRECTV box are hardwired.  There are various phones and Roku's, and a printer that is wireless.
      I have not done a factory reset, not sure how to do that.
      Thanks
      • plemans's avatar
        First off, you're in a double nat as that modem is a modem/router combo device.
        A double nat happens when you cascade more than 1 router.
        https://kb.netgear.com/30186/What-is-Double-NAT
        Fixes? There’s 3 options but only use 1.
        1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
        2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
        3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
        https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
