orangeshed
Jun 13, 2021Aspirant
RAX50 TxPkts and RxPkts always zero
I have noticed that the port statistics on my RAX50 router always show 0 for the TxPkts and RxPkts columns. This is obviously wrong for the ports that are connected, as there has definitely been acti...
orangeshed
Jun 14, 2021Aspirant
Thanks for the advice Razor512 .
I tried doing a factory reset earlier today. I had a feeling that restoring the config from backup would restore the problem, so re-entered all my settings from scratch.
And after changing everything back to how it was before ... TxPkts and RxPkts were all zero. This is what it looked like 4 hours after the factory reset:
Unfortunately I was so certain that doing this would work that I didn't check the stats between every config change, so I don't know which setting caused this, or even if it was like this all the way through because something is permanently broken in my hardware.
Tomorrow I will try the factory reset process again and check the stats at regular intervals during the config updates.
orangeshed
Jun 15, 2021Aspirant
I tried another factory reset, and looked at the stats as early as I could in the setup process, and all the TxPkts and RxPkts values were still zero:
So I guess that means either there's something wrong with part of the hardware on my RAX50 or else it remembers something through a factory reset that causes the problem.
Interestingly it does remember some things through a factory reset, because after my two factory resets on consecutive days my traffic meter statistics are still showing last month's usage correctly:
Anyone know if those figures are remembered on the device itself or somewhere in the Cloud? If it's on the device it would be interesting to know if there's a secret way to do a real factory reset that includes absolutely everything.
I'm going to open a support case about this.
- Razor512Jun 15, 2021Prodigy
Netgear doesn't store that info in the cloud, thus it seems some deta is being left behind after the factory reset.
