DLynch1
Jan 07, 2022Tutor
RAX50 updates
Won’t update firmware. Suggestions?
Jan 07, 2022Guru - Experienced User
What firmware version are you on?
What error are you getting?
Where in the process is it failing?
Details are key in helping figure out where its going wrong/failing.
- DLynch1Jan 07, 2022TutorUsing App, ios
Version V1.0.2.82
Router settings, check for updates
“Firmware check error
There was a problem checking firmware update. Skip or Try Again”- plemansJan 07, 2022Guru - Experienced User
Have you tried doing a manual firmware update?
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
- DLynch1Jan 07, 2022TutorI haven’t. Not sure how to. I’ll look into it. Thank you.
