DLynch1
Jan 07, 2022Tutor
RAX50 updates
Won’t update firmware. Suggestions?
DLynch1
Jan 07, 2022Tutor
Using App, ios
Version V1.0.2.82
Router settings, check for updates
“Firmware check error
There was a problem checking firmware update. Skip or Try Again”
Version V1.0.2.82
Jan 07, 2022Guru - Experienced User
Have you tried doing a manual firmware update?
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
- DLynch1Jan 07, 2022TutorI haven’t. Not sure how to. I’ll look into it. Thank you.
