ikonuk
Jun 27, 2023Guide
RAX50-V1.0.15.128_hotfix firmware update does not install on NETGEAR AX5400 Router (RAX54S-100NAS)
I used the web interface of the router to upload the "RAX50-V1.0.15.128_2.0.89.chk" file. It uploads and attempts to install. It does not reboot. I had to manually reboot the router. It comes back with the original firmware version.
Is this up=date compatible with the model RAX54S-100NAS?
Thanks friends. That (correct firmware) worked. It was my carelessness!
- microchip8MasterIt is. Make sure to download the correct version for your hardware revision (v1 or v2)
Check the sticker under the router for version #.
Is this the version you found?
RAX54S Firmware Version 1.0.15.128 - Hot Fix | Answer | NETGEAR Support
Firmware and model numbers usually have to be an exact match.
- ikonukGuide
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
