Javadrinker
Dec 05, 2021Aspirant
RAX50
RAX50 latest firmware not that it makes any difference at all. This router has had 5G issues since i bought it. I gave up talking to support as I got no where rebooting and factory resetting the dam...
Javadrinker
now I have to log out of everything, and go reboot the system..you know cable modem, router, security system, wifi extender...
DarrenM
Dec 06, 2021Sr. NETGEAR Moderator
Is the extender too far from the router to get a good 5ghz signal?
DarrenM
- JavadrinkerDec 06, 2021Aspirant
This is NOT about the extender this IS about the router. I have 3 laptops within 6 ft. of the router. IF using the 5GHz band it says "Connected,secured" but if you attempt to go to oh lets use Netgear.com and you get 1) the connection timed out, 2) This page cannot be displayed, or best yet 3) just nothing. Switch to 2.4GHz band and everything works.
- DarrenMDec 07, 2021Sr. NETGEAR Moderator
I suggest contacting support could be a hardware issue happening with the router. https://my.netgear.com/support/contact.aspx
DarrenM
- JavadrinkerDec 09, 2021Aspirant
Netgear has support? I contacte support 2 days ago, described the issue and also asked for a replacement. Other than the auto generated do not reply to email, there has been no communication. A far cry from what used to be Netgear and Netgear support. I guess I will be replacing this router, extender and switch with another brand.
