Kicker96fs
May 02, 2023Aspirant
RAX50
ust got his up and running this past weekend, hooked everything up. Then they pushed a firmware update the other night and now I can't get my Nest thermostat to find it, now my wifi light bulb controlled by Alexa, nor does it find itself in the nighthawk app!
I have rebooted the router to no avail.
I had a heck of a time getting Alexa to find it. All this after the update to firmware V1.0.12.120_2.0.83
Any ideas?
Thanks in advance!
1 Reply
Anytime there's an issue after a firmware update, a reasonable first response would be to try a factory reset and reinstall.
Have you tried this?
