N1PS
Oct 22, 2020Aspirant
RAX50S router unidentified network
I recently purchased and installed this router. There are about 10 devices connected to the router at various times. The PCs at times lose the internet and display "Unidentified Network" when you h...
Dan32
Oct 23, 2020Apprentice
Have you ever updated the firmware? The latest version as of today is 1.0.2.72. It has a massive list of fixes.
If you are on this version, you might want to try to reset the router to factory defaults and re-install it again. Then re-configure from scratch any custom changes you previously made. Do not save and reload a configuration file. If not, then do the same.
The other thing to look at, is your Wifi drivers on your PC's. If you are using Intel AX cards, or any of the newer Intel AC cards that all use the same Proset drivers, you might want to head over to the Intel site and grab the lastest drivers (and for bluetooth as well as they are separate). You won't necessariy get the latest drivers from Windows Update.
- N1PSOct 23, 2020Aspirant
TNX. The router firmware is up to date and the PCs have the latest drivers.
- KillhippieOct 25, 2020Prodigy
Have you reset the router via the small pinhole in the back to factory settings
- rinthosOct 25, 2020LuminaryI seem to have similar experiences on two RAX50 devices I deal with.
Issue seems to impact 1.0.2.72 firmware as well.
Here is what I've found so far as well as a temporary workaround that I'm using...
RAX50 has:
Netgear Armor Enabled
IPv6 Enabled (DHCP w/ Comcast Xfinity)
QoS is Enabled using Speedtest to set upload and download thresholds, and thr Media QoS database is updated as of August 2020.
Beyond "Unknown" i also get "No Internet" and sure enough even the local LAN IP of the Router stops responding.
The easiest fix has been to disable IPv6 AND turn off QoS, then reboot. Leaving Armor on still seems workable...- N1PSOct 25, 2020Aspirant
OK....I dont want to do a hard reset as yet. Another issue just came up....I seemed to have accidentally engaged Armor and It needs to go away. How do I disable it in the admin pages? If I click on the Armor icon nothing happens. Everything I read lists using a cellphone (I do not have a fancy phone) to turn this mess on/off. This Armor crap needs to go away!!!!! It seems to be like a virus.
