mjlemay
Nov 08, 2022Follower
RAX50's SSID reverting to default
Hi, Without any warning, my router SSID reverted to their default value tonight. Automatic update is enabled. My firmware version is 1.0.12.120_2.0.83. A quick search on NetGear web site doesn't ...
MLBmn
Dec 13, 2022Aspirant
Same exact issue. Firmware V1.0.12.120_2.0.83
Dec 13, 2022Guru - Experienced User
Factory reset the router and setup from scratch. Might manually load FW to the router using MS edge or Firefox with a wired PC, then after it's loaded, factory reset and setup from scratch.
