LaSabana
Nov 06, 2023Aspirant
RAX50v2-NightHawk
I recently updated to this NightHawk RAX50v2. Previous to this upgrade I was using Orbi Mesh RBR 20/RBW 30(plug in satellite). Can anyone advise if I can use any component of ORBI Mesh as WiFi extend...
Nov 06, 2023Guru - Experienced User
Only EX or EAX series extenders will work with the RAX. Orbi is only supported and compatible with in Orbi systems.
- LaSabanaNov 06, 2023Aspirant
Thanks Furrye38. i appreciate your response. So only EX or EAX extenders will work w/ my Nighthawk RAX50v2- is it worth locating a used extender?
- FURRYe38Nov 07, 2023Guru - Experienced User
Of course. Might find a refurb'd one on amazon or find something used on ebay or shopgoodwill.
