Draketungsten
Jul 30, 2023Aspirant
Rax54 Access Control
When I log in to my Rax54 and go to the Access Control function, it tells me that I have to use the Nighthawk App. When I got to the Nighthawk App, it doesn't give me the control I'm looking for. I...
Kitsap
Jul 31, 2023Master
Draketungsten wrote:When I log in to my Rax54 and go to the Access Control function, it tells me that I have to use the Nighthawk App. When I got to the Nighthawk App, it doesn't give me the control I'm looking for. I want the granular control that the Web GUI use to give me, Deny all new MACs. Or at the very least all new MACs added to a default access group.
Completely reset the router and still getting the same result. Screenshot attached.
Anyone else running in to this?
This is the first I have seen of this issue. Any chance you are running beta or hotfix firmware?
What firmware is installed on your RAX54? What version of the Nighthawk application are you using?
You might check over in the community dedicated to the Nighthawk application. Try here: https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
- DraketungstenJul 31, 2023Aspirant
I was running the latest stable version, 1.0.12.120. I updated to the latest hot fix, 1.0.15.128, to see if that would fix the problem but it didn't.
I'll go drop a message over on the Nighthawk App forum too.
