jlwaldrup
Mar 14, 2023Follower
RAX54 internet connection not secure
See original Case number 46693438 in product support. Frontier Fios is ISP (originally Verizon). Verizon Gateway router model GS1100. Netgear router is Nighthawk AX6 AX5400 6-str...
Mar 14, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Try option #2 first...
- PaulGoMar 21, 2023Luminary
FiOS and other fiber connections do not use a modem the ONT acts as a modem. If you are just using internet you can connect the RAX54 directly without the G1100. If you need the G1100 for TV or telephone then this thread may help:
