dgutierr27
Sep 20, 2023Aspirant
RAX54 Security Access Control settings reset after power loss
I have a Nighthawk RAX54 running Firmware Version V1.0.12.120_2.0.83. I have the router configured with Security - Access Control disabled. But, whenever I have a power outage at home, and once ...
dgutierr27
Mar 27, 2024Aspirant
Nope. Still keeps happening. A reboot even reverts the SSID password to one from an older configuration! Wondering if it's similar to this old post. https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Nighthawk-X4S-R7800-Loses-Config-after-reboot/td-p/2073601
Looks like I won't be buying Netgear again.
Mar 27, 2024Guru - Experienced User
Have you tried updating FW to see if this resolves this?
I recommend that if you manually load this version of FW, perform a factory reset and setup from scratch using a wired PC and web browser: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- dgutierr27Mar 27, 2024Aspirant
Yes, this behavior happened on previous FW and latest/greatest. Have done factory resets, restored from backup, no change. I just ordered another router (same model), and will see if this is a hardware issue on mine. Even though it worked fine for over a year so this feels like FW defect.
- FURRYe38Mar 27, 2024Guru - Experienced User
Ok so lets try a factory reset and this time, do not apply a backup configuration from file. Possible you maybe re-introducing or the problem is following on from a older backup file created on a older version of FW and populating that with a new version of FW.
Something else to try as well, 30-30-30 reset and again setup from scratch, do not load a saved configuration from file.
