Ann743
Feb 09, 2025Aspirant
RAX54 v 2 Won't transmit 2.4Ghz
I just opened & set up a new RAX54v2 yesterday. At first I only enabled the 5GHz. That connected well. Then I realized my printer only connects to the 2.4GHz. So I went back into the router progr...
- Feb 09, 2025
Been working on this for hours, but I found the solution. I had enabled 2.4 SSDI broadcast in the Basic section & thought that was it. But I just found I also had to enable the 2.4 router radio in the advanced section. Dang! You basically need a computer degree to get your router programmed for your needs. I'm going to bed now for about 4 hours until its time to get up again.
Ann743
I noticed when I'm in the Router Settings & comparing the 5Ghz set up to the 2.4 set up (Advanced Home Page), it says Wireless AP in on for the 5G, but is off for the 2.4. I don't see a setting to change this.
