ph3l0n's avatar
ph3l0n
RAX54 v1.0 - Constant Crashing
As the title states, my router is constantly crashing.  First the GUI fails and then shortly there after, the whole of the router fails.   I have to manually restart the router for it to work again. ...
  • FURRYe38's avatar
    Oct 09, 2023
    Probably best to return it.
    Good Luck.
