ph3l0n
Oct 09, 2023Aspirant
RAX54 v1.0 - Constant Crashing
As the title states, my router is constantly crashing. First the GUI fails and then shortly there after, the whole of the router fails. I have to manually restart the router for it to work again. ...
- Oct 09, 2023
Probably best to return it.
Good Luck.
ph3l0n
What are your thoughts on this? Hardware failure?
Oct 09, 2023Guru - Experienced User
Probably.
Try another one or different model series.
- ph3l0nOct 09, 2023Aspirant
Is this common a common problem for this router or this vendor? I have seen that other router variations RAX8000 has had the same issue through googling a fix. I am kind of leary with buying another router from NetGear, but I like the router gui, which makes me not want to jump ship to another router manufacturer..
- FURRYe38Oct 09, 2023Guru - Experienced User
No. Maybe a Mfrg defect or part that went bad. Not all routers are bad. Just maybe one bad go thru or was a bad batch is all. Try a different model series or same one from store or online etailer.
RAX8000 is not a valid router model.
https://www.amazon.com/NETGEAR-Nighthawk-Smart-Wi-Fi-Router/dp/B00KWHMR6G - This router is what I was referring to.
