WAG53's avatar
WAG53
RAX54S setup
I'm trying to setup my RAX54S-100NAS.  I've downloaded the Nighthawk app. I get through the setup but it diverts to the WI-Fi networks on my phone, I choose the Netgear network that's for my router and that's as far as I get. It won't complete the setup.
  • Thanks for your reply. I finally got the app to work after a modem swap with my new provider. Everything is working great. Thanks again. Steve
    Attempting to setup/configure a Netgear router using the mobile application has shown to be problematic in many situations.  Experienced Netgear users prefer to configure the router via the web based user interface.  First preference is to connect to your router via an Ethernet cable.  If not available, a Wi-Fi connection should work.  See here for instructions.
      https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    • WAG53's avatar
      WAG53
  • I understand your frustration with the setup process. To effectively configure your RAX54S-100NAS router, ensure you're connecting to the router's network, not your phone's Wi-Fi. Once you've selected the Netgear network, proceed with the setup in the Nighthawk app. If you encounter any issues, consult the user manual or visit Netgear's support page. For a more detailed guide, see the blog. Stay patient, and you'll soon have your network up and running smoothly.
    • WAG53's avatar
      WAG53
      App finally worked after a modem swap with a new provider. Thanks for responding, Steve
