CrazyVegan
Nov 18, 2022Aspirant
RAX54S vs RAX29?
What are the main differences?
Nov 19, 2022Guru - Experienced User
RAX54: iFi 6 (802.11ax) dual band WiFi (AX5400)
- 2.4GHz AX: 2x2 (Tx/Rx) 256-QAM
20/40MHz, up to 574Mbps
- 5GHz AX: 4x4 (Tx/Rx) 1024-QAM
20/40/80/160MHz, up to 4.8Gbps
RAX29: WiFi 6 (802.11ax) Dual Band WiFi (AX2400)
- 2.4G: 574Mbps, 40/20MHz
1024/256-QAM
- 5G: 1800Mbps, 80/40/20MHz
1024-QAM
- CrazyVeganNov 19, 2022AspirantSo should I pay the extra $30 for the RAX54S? If so, why?
- michaelkenwardNov 19, 2022Guru - Experienced User
CrazyVegan wrote:
So should I pay the extra $30 for the RAX54S? If so, why?What do you plan to do with this thing?
Broad brush questions aren't amenable to detailed answers.
What do the reviews say?
What have you discovered from wandering around in this place?
Which would look best on the shelf? Three or four antennae?
