SnoShu
Nov 24, 2024Aspirant
RAX54S Wireless (5GHz) speed
I have a RAX54S router Version 1. While it seems to be working, I'm unable to get 5GHz wireless speeds faster than 350Mbps (using Ookla's SPEEDTEST). Using the wired connection, I'm able to achieve...
- Nov 25, 2024
If you want to understand more about wifi speeds,
read here:
Its goes a bit into depth but the basic overview will detail wifi speeds.
What devices are you testing with (in detail). That helps us determine if the 433mbps link speed is correct for your device or if it should be higher.
Nov 24, 2024Guru - Experienced User
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
- SnoShuNov 25, 2024Aspirant
Thank you for those links!
- plemansNov 25, 2024Guru - Experienced User
If you're link speed is 433mbps, your 325-350mbps is about all you can expect. Actual throughput is around 55-65% of link speed. So you're hitting above that so your at the higher end of efficiency. You'd need a better device to hit faster speeds as yours is only connecting at a 1x1 antenna speed rate.
read here:
