SnoShu
Nov 24, 2024Aspirant
RAX54S Wireless (5GHz) speed
I have a RAX54S router Version 1. While it seems to be working, I'm unable to get 5GHz wireless speeds faster than 350Mbps (using Ookla's SPEEDTEST). Using the wired connection, I'm able to achieve...
- Nov 25, 2024
If you want to understand more about wifi speeds,
read here:
Its goes a bit into depth but the basic overview will detail wifi speeds.
What devices are you testing with (in detail). That helps us determine if the 433mbps link speed is correct for your device or if it should be higher.
Nov 25, 2024Guru - Experienced User
what link speed are they reporting?
What firmware version are you on?
have you tried disabling armor, traffic monitoring, parental controls?
what modem/gateway is it connected to?
- SnoShuNov 25, 2024Aspirant
what link speed are they reporting? Reported link speed is ALWAYS 433Mbps
What firmware version are you on? As I indicated in my original post, I have used four of the five available firmware levels. My router is currently at Version V1.0.16.132_2.0.92 (most current available from Netgear)
have you tried disabling armor, traffic monitoring, parental controls? I do NOT use "armor", I do NOT use "traffic monitoring", I do NOT use "parental controls"
what modem/gateway is it connected to? This router is connected to an Arris SB8200 DOCSIS 3.1 Ultra Fast Cable Modem. The wired RJ45 connection is consistently 850-900Mbps down and 50-52Mbps up
and yes, I have power cycled both the modem and router and revisited the connection speeds.
All tests and reporting are done with my cell phone, tablet or notebook approximately 6' to 8' from the router.
I have run the tests at all hours of the day - 1am, 3am, 5am, 9am, 1pm, 4pm, 9pm with the same results. Reported link is 433Mbps, speed tests are between 325 and 350Mbps.
