SpamKiller007
Feb 19, 2023Follower
RAX54Sv2 - Nighthawk AX6 6-Stream AX5400 WiFi Router (Costco)
I just picked up a new router from Costco. I have been reading about routers installed with DumaOS 3.0 and was wondering if it is possible to install on my new router. The current firmware version ...
Feb 19, 2023Guru - Experienced User
The firmware might be different because sometimes they push out updates on the auto-update server first. Then the manual update site later.
