NtHwNG
Oct 29, 2024Follower
RAX54v2: disable port forward checkbox
My trusty old Netgear router had an enable/disable feature for each port forward assignment; allows you to turn it on/off as opposed to needing to delete and recreate the rule each time. The RAX54v2 with firmware V1.1.4.28_2.1.26 does not seem to have this feature. Am I missing something, or has user friendliness gone backwards?
1 Reply
Can you post a screen capture of what is displayed on the routers web page for this?
Is uPnP disabled on the router?
What browser are you using? Happens in other browsers?
