krk_
Feb 09, 2024Aspirant
RAX54v2 going offline every night
Over the past week, overnight around 3:30-3:45, my wireless router goes down. No errors indicated by the LEDs, wireless SSIDs still broadcasting, but you cannot join. A reboot restores connectivity bu...
krk_
Feb 13, 2024Aspirant
So, I think I’ve found part of the problem.
After checking, I’m on v1.1.3.18. When I check for an update manually, there is a 1.1.4 version. However, after multiple tries to upgrade to the new version of firmware, the router just hangs (just like it does overnight).
So, I went into advanced settings and noted that automatic updates were enabled. This is what is causing the router to die overnight. So, I disabled for now.
Now, the problem is that the router will not take the new firmware. Not sure what to do about that.
michaelkenward
Feb 13, 2024Guru - Experienced User
How are you trying to load the new firmware? Manual is best:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You shouldn't need to do it, but it sometimes helps to reset the device before you apply the firmware.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
You could save your settings and reload them after the update.
That can resurrect problems from before the backup, bit in this case there may not be any.
