curboys's avatar
curboys
RAX70 — Nighthawk Tri-band AX8 8-Stream AX6600 WiFi 6 Router Model / Version: RAX70
This router comes with four ethernet ports.  How do I expand the number of Ethernet ports ?
What Netgear WIFI Extender works best with this router?
Thanks in advance
  • How do I delete message #2 of 3?
    ‎2024-10-10 11:52 AM
    What wifi extender works best with this router?
    Thanks in advance
  • michaelkenward's avatar
    michaelkenward
    It is easy to say "buy this, buy that", but it you might better advice if you explained what you are trying to achieve.
    There are various combinations of devices that can work in different scenarios. Tell us a bit more about your layout and someone might be able to come up with informed advice.
    For example, do you want an extender that plugs into the router?
    Do you want more Ethernet ports out of the extender or plugged into the router?
    Just another user with time on their hands.
