newjoiner
Dec 23, 2021Apprentice
RAX70 - Where can I enable DNS over HTTPS (DoH) feature?
Hi, I am a new joiner to Netgear. As I know there are a new RAX70 Firmware Version 1.0.11.112 released today, and added a new feature: Supports DNS over HTTPS (DoH). Could I know how to enab...
- Jan 26, 2022
I have install AdGuard Home as my DNS Server now as alternative.
However, I have also opened a support case with below reply for your reference.
Reply from Support Case by Sunaya, NETGEAR Network Specialist:
Upon consulting the case, please be informed that there is no option in the GUI to enable/disable this feature. In general, this protocol will increase user privacy. For more information, please refer to the link below.
https://en.wikipedia.org/wiki/DNS_over_HTTPS
CarstenNL
Jan 28, 2022Aspirant
DNS over HTTPS
Web browsers, look in privacy/security.
On android,
First, go to Settings->Network & Internet->Advanced. In there, you will see an option for Private DNS, which should be Off by default. Switch it from Off to "Private DNS provider hostname" and specify the DNS provider you want to use.
Example,
doh.opendns.com
1dot1dot1dot1.cloudflare-dns.com
Test DoH,
https://umbrella.cisco.com/doh-help
https://1.1.1.1/help
On android,
Example,
doh.opendns.com
Test DoH,
