Godofkitchen
Apr 01, 2021Follower
RAX70-100NAS would not stay connected to wireless or wired connection
I just bought this new router RAX70-100NAS Tri-band router. Installed it last night and everything was connecting up, and I updated devices to connect to the 2.4G & two 5G bands it had. I also had...
michaelkenward
Apr 02, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
