Odunkur
Mar 10, 2023Guide
RAX70 5G-2 SSID problem
Hi,
I have noticed that in the wifi setup on the RAX70 with regards to the 5G-2 SSID.
When I select the Mode 'Up to 4803 Mbps', it takes ages for the SSID to show up and you can't connect to it either until it shows up. If you set it back to default mode, namely 'Up to 2401 Mpbs' it shows up immediately after a reboot.
What's causing this and why? Is this happening to others as well?
I have NON RADAR near by
A couple things.
1.you might think you have no radar in your area but its not impossible. Its not just airports that use dfs frequencies for radar
2. Even if there isn't, it still has to scan to ensure that there isn't any. So it'll take longer using dfs channels
- OdunkurGuide
The RAX70 only works at 80MHZ, se picture. when i set full speed the 5G-2 (160MHZ) wont be found in the Wifiinfowiuv application or on my devices. No airport or radar nearby. My old R7800 worked on 160HZ whit DFS channels.
Edit:
I almost get the same wifi speed as i get wired from my ISP (1Gbps download and 700Mbps upload) so its faster than the r7800 router.
The only way to set 160MHZ is to set the fastest speed but it doesnt work after that.
What region is the router set in?
I notice your speedtest location is stockholm.
