jkimbro
Jan 17, 2022Tutor
RAX70 and IP cameras
Hey all,,, I just got a Nighthawk AX8 AX6600, (RAX70) and I'm having an issue with my IP cameras disconnecting. They usually connect again after a few minutes but then will disconnect again. These a...
Jan 17, 2022Guru - Experienced User
Are they 2.4ghz camera's?
Have you tried changing which channel the router is on?
jkimbro
Jan 18, 2022Tutor
I actually have changed channels for other reasons but issue is on cams that are both wifi and ethernet so it won't be an RF interference issue
- CarstenNLJan 18, 2022AspirantTry setting the band used for long distance Preamble-modus from Auto to Long preamble.
It made mine stable- jkimbroJan 18, 2022Tutor
I'll give that a try,,, thanks
- plemansJan 18, 2022Guru - Experienced User
what camera's are you using?
Do they have a hub?
What modem/gateway is the router connected to?
How do you have everything wired if even the wired camera's are dropping?
(everything back to the nvr hub? through a switch? through the router?)
what camera's are you using? Various REOLINK cams
Do they have a hub? No,, no hub. IP cams
What modem/gateway is the router connected to? The RAX 70 router is connected to a Netgear DNGD4000 modem/router, (my old router)
How do you have everything wired if even the wired camera's are dropping? Not sure what you mean? Some of the cams are POE so obviously connected to a POE switch,, the others are IP WIFI cams
(everything back to the nvr hub? through a switch? through the router?) No NVR hub. The NVR connects directly to a switch wich connects to the router
