braylor
Jun 07, 2022Aspirant
RAX70 Blocking Roku Channel
Nighthawk Tri-Band AX8 RAX70 Firmware V1.0.12.114 After a lot of troubleshooting with Roku community, and our ISP Spectrum Internet stating they don't block apps or websites, it seems our RAX70 i...
Jun 07, 2022Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 10 seconds then release.
Be sure to not enable Armor or Smart parental controls.
- braylorJun 07, 2022Aspirant
Modem is Spectrum E31U2V1 DocSIS 3.1 eMTA cable modem
A factory reset of the RAX70 hasn't been performed. Once we have time and opportunity, we'll perform Factory Reset on the RAX70 and see it that resolves it. We'll post an update once we do.
- braylorJun 13, 2022AspirantFirmware V1.0.12.114
Modem Spectrum E31U2V1 DocSIS 3.1 eMTA cable modem
We performed a factory reset on the RAX70 and it's still blocking Roku Channel - Error 451.
Armor and Parental Controls haven't been enabled. The only changes made were the admin password and name of the SSIDs.
Could this be a firmware issue? It didn't give us a chance to not update the firmware. It did it automatically during setup. - braylorJun 13, 2022Aspirant
Also wanted to add that DNS are set to 8.8.8.8., 8.8.4.4., and 1.1.1.1. after the Factory Reset. We performed a DNS flush and everything has been rebooted.
We can play videos on the Roku Channel if we connect Windows 10 laptop, or Roku TV, directly to the modem with an ethernet cable. ISP isn't blocking and the issue isn't with the modem.
As stated, Roku Channel was working just fine until about a month ago, which is around when we updated the RAX70 firmware. We can find no router settings that are causing the block, so it's most likely the firmware.
How can we get earlier versions of the firmware and roll it back manually on the router to check this?
- braylorJun 14, 2022Aspirant
We applied all new previous firmware versions available for RAX70 but we're still getting Error 451.
For every previous firmware version, we rebooted everything before trying to play video from the Roku Channel in a browser on Windows 10 laptop. We tried Factory Reset of the RAX70 again as well but it won't let us bypass updating the firmware.
We're not sure why rolling back the firmware didn't work, but there must be some setting on the RAX70 causing the block that we can't figure out. Especially since there was no issue a month ago and we can play video on the Roku Channel just fine with either VPN or plugging into modem directly.
- braylorJun 21, 2022AspirantWe found our old Asus RT-AC3200 router and tried it. The Roku Channel works just fine with that. Confirmation that there's something wrong with the Netgear RAX70.
We're very disappointed at the lack of help from Netgear on this issue. We'll be replacing our Netgear with Asus and steer clear of Netgear products from now on. - FURRYe38Jun 21, 2022Guru - Experienced User
Did you factory reset the router and setup from scratch after loading a prior version of FW?
Possible the DMZ on the router may help test for this with the Roku in the DMZ...
You don't have any Armor or Smart Parental controls enabled or had been enabled?I see you posted here too:
Also others seeing similar issues with Roku:
RAX70 has been factory reset and re-setup several times before and after loading FW versions. Netgear forces updating to the newest FW version upon setup, though. We rolled back to the most previous FW version to check that there was still an issue.
Armor and Smart Parental controls are not and have never been enabled.
Netgear shows location as North America. We're not sure how to access or change settings for DMZ. We've tried changing DNS to 8.8.8.8, 1.1.1.1., and 8.8.4.4. to no avail.
