braylor
Jun 07, 2022Aspirant
RAX70 Blocking Roku Channel
Nighthawk Tri-Band AX8 RAX70 Firmware V1.0.12.114 After a lot of troubleshooting with Roku community, and our ISP Spectrum Internet stating they don't block apps or websites, it seems our RAX70 i...
Jun 07, 2022Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 10 seconds then release.
Be sure to not enable Armor or Smart parental controls.
braylor
Modem is Spectrum E31U2V1 DocSIS 3.1 eMTA cable modem
A factory reset of the RAX70 hasn't been performed. Once we have time and opportunity, we'll perform Factory Reset on the RAX70 and see it that resolves it. We'll post an update once we do.
