daviddobromirov
Jul 15, 2024Aspirant
RAX70 Cable can not be detected
Hello, My router out of nowhere cannot detect the modem. I even tried factory reseting the router and then it says that cable cannot be detected. I am out of ideas how to fix this. Plea...
Jul 15, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
daviddobromirov
Current firmware version is v1.0.15.146.
Modem is Spectrum ET2251.
I now changed to CAT6 cable. I had some yellow garbage on it.
Yes, I turned off both modem and router for 2 minutes + and then back on, and nothing.
I factory reset and then I again redid the steps and nothing.
Best regards,
David
- FURRYe38Jul 15, 2024Guru - Experienced User
Can you connect a wired PC or laptop to the modem and see if the PC or laptop gets any internet?
- daviddobromirovJul 15, 2024Aspirant
I connected my laptop and it does not recognize the ethernat cable. I will go now exhange the modem.
đ
