daviddobromirov
Jul 15, 2024Aspirant
RAX70 Cable can not be detected
Hello, My router out of nowhere cannot detect the modem. I even tried factory reseting the router and then it says that cable cannot be detected. I am out of ideas how to fix this. Plea...
daviddobromirov
Current firmware version is v1.0.15.146.
Modem is Spectrum ET2251.
I now changed to CAT6 cable. I had some yellow garbage on it.
Yes, I turned off both modem and router for 2 minutes + and then back on, and nothing.
I factory reset and then I again redid the steps and nothing.
Best regards,
David
Jul 15, 2024Guru - Experienced User
Can you connect a wired PC or laptop to the modem and see if the PC or laptop gets any internet?
- daviddobromirovJul 15, 2024Aspirant
I connected my laptop and it does not recognize the ethernat cable. I will go now exhange the modem.
- FURRYe38Jul 15, 2024Guru - Experienced User
đ
Exchanged the modem, and the router is back up and running, thank you so much for the help!
Best regards,
David
