user6
Jun 03, 2022Aspirant
RAX70 cannot display attached devices
The RAX70 is a $350 router. It cannot display a list of attached devices on the LAN out of the box with the latest firmware. Does anyone know why?
- Jun 03, 2022
What mode is the ISP modem working in? Router or bridged?
Try a different PC to compare?
Might try reverting back one FW version to see if this resolves.
Jun 03, 2022Guru - Experienced User
What browser are you using? Try MS Edge, FireFox or Opera?
Be sure to clear out all browser caches before entering into the routers web page.
user6
Thanks FURRYe38
Router Firmware Version V1.0.12.114
Issue exists in Chrome, Safari, and Firefox with cleared cache
Router is connected to a Verizon Internet Gateway model No. ASK-NCQ1338
- FURRYe38Jun 03, 2022Guru - Experienced User
