user6
Jun 03, 2022Aspirant
RAX70 cannot display attached devices
The RAX70 is a $350 router. It cannot display a list of attached devices on the LAN out of the box with the latest firmware. Does anyone know why?
- Jun 03, 2022
What mode is the ISP modem working in? Router or bridged?
Try a different PC to compare?
Might try reverting back one FW version to see if this resolves.
user6
Thanks FURRYe38
Router Firmware Version V1.0.12.114
Issue exists in Chrome, Safari, and Firefox with cleared cache
Router is connected to a Verizon Internet Gateway model No. ASK-NCQ1338
Jun 03, 2022Guru - Experienced User
- user6Jun 03, 2022Aspirant
Indeed it has.
- FURRYe38Jun 03, 2022Guru - Experienced User
Might try reverting back one FW version to see if this resolves.- user6Jun 03, 2022Aspirant
Success! The solution was to set the ISP gateway to bridged mode, and not router mode. Devices appeared after the router was power cycled.
FURRYe38 My network devices were connected to the router, and not the gateway. For us plebs, can you explain why the router would have trouble finding attached devices if the ISP gateway was not set to bridged mode?
