Johncorsaro
Dec 06, 2022Aspirant
RAX70. Changing to 10.0.0.1
Router set to 10.0.0.1. Went into advanced settings and checked off router mode several times and saved config. Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This d...
Dec 06, 2022Guru - Experienced User
Why not just use access point mode if you're wanting dhcp disabled?
- JohncorsaroDec 06, 2022AspirantI never wanted to disable dhcp nor pass thru or as bridge. The router decided to do it automatically . Which should never happen unless done so thru advanced settings.
