Johncorsaro
Dec 06, 2022Aspirant
RAX70. Changing to 10.0.0.1
Router set to 10.0.0.1. Went into advanced settings and checked off router mode several times and saved config. Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This d...
michaelkenward
Dec 06, 2022Guru - Experienced User
Johncorsaro wrote:
Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This day 2 of installing the router.
A sign that the RAX70 is behind another router and the setup process is trying to avoid problems.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
Or just go for AP mode as plemans advises:
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
Or explain exactly what you are trying to achieve with this juggling trick.
Johncorsaro
Not running behind another router. Is connected directly to cable modem that has no router capabilities. Please update firmware so these modes can only be achieved if the end user chooses that mode…thru the UI menu
