Johncorsaro
Dec 06, 2022Aspirant
RAX70. Changing to 10.0.0.1
Router set to 10.0.0.1. Went into advanced settings and checked off router mode several times and saved config. Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This d...
Johncorsaro
Not running behind another router. Is connected directly to cable modem that has no router capabilities. Please update firmware so these modes can only be achieved if the end user chooses that mode…thru the UI menu
Dec 06, 2022Guru - Experienced User
1. we're not netgear.
2. if you're disabling dhcp and don't have another router connected, of course you're going to have issues. A modem only device needs a router connected thats handling dhcp/nat. If you're disabling that, what result do you think you'll get?
