Johncorsaro
Dec 06, 2022Aspirant
RAX70. Changing to 10.0.0.1
Router set to 10.0.0.1. Went into advanced settings and checked off router mode several times and saved config. Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This d...
Johncorsaro
Not running behind another router. Is connected directly to cable modem that has no router capabilities. Please update firmware so these modes can only be achieved if the end user chooses that mode…thru the UI menu
michaelkenward
Dec 07, 2022Guru - Experienced User
So why are you trying to disable the router bit of the RAX70?
What do you expect to carry out that function for you you on your network?
What is this anonymous cable modem?
And, as I suggested before:
"explain exactly what you are trying to achieve with this juggling trick".
