RickWu
Jun 22, 2021Tutor
RAX70 DNS cannot be resolved
Hi Netgear In RAX70 DNS using "ISP dynamic acquisition" or "manual setting", the device I have on hand often fails to resolve DNS, and the DNS must be set on the client device to resolve it normally...
Christian_R
Jun 29, 2021NETGEAR Employee Retired
Hello RickWu,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- RickWuJun 29, 2021Tutor
A case has already been opened. It seems that many people in the forum have these problems, but you don’t pay much attention to this problem.
- rubenszOct 30, 2021Tutor
I've tried 2 RAX70 bought from Amazon. Both same bad experience.
Probably I will return it to amazon as the 1st one (sent back because I thought warehouse issue), not sure I will try to bought the 3rd, it is really insane activity.
Please Netgear give a kind of solution. thanks
