jvkoepfer
Sep 25, 2022Aspirant
Rax70 getting error The product's country of purchase is not valid. at registration
Bought this on Amazon. Live in Arizona. Reg. screen not letting me add a "country of purchase" I see its been solved but how?
michaelkenward
Sep 26, 2022Guru - Experienced User
What is this "Reg. screen"? Where did you see it?
You do not need to register anything to use your device.
Registration is usually just needed for warranty and support purposes and starts here:
- jvkoepferSep 26, 2022AspirantBy reg screen I meant registration screen on Netgear web site
I wanted to register in case I need to open a ticket
Not having problems right now- michaelkenwardSep 27, 2022Guru - Experienced User
Not having problems right nowSadly, there are several places you could call the "Netgear web site".
Was it the one I provided a link to?
You should be able to create an account for yourself there without feeding in any details for your device.
First create the account, then add your new router.
NETGEAR - Common Account Management
That is where you get the drop down option for your country.
You said earlier:
Bought this on Amazon.That does not mean that Amazon was the supplier. Maybe some box shifter picked up a bunch of devices somewhere and used Amazon as a store front. We have seen cases of that here before.
- jvkoepferSep 27, 2022Aspirant
this the site i tried to use for registering the device is:
it doesn't provide a place for entering the purchase country, just date of purchase and serial number are there.
I guess its picking up country from the digits in the serial number.
