stolnsol
Jan 14, 2021Star
RAX70 Help Identifying the 4x4 5G and the 2x2 5G
Netgear fam, I just picked up the RAX70 from Best Buy. So far so good. Since it's Tri-band and one of the 5Ghz network is 2x2 and the other is 4x4 my plan is to setup the 4x4 network for my AX device...
Jan 15, 2021Guru - Experienced User
The band 2 4800mbps is the 4x4 band. (1200mbps x4)
per the data sheet:
• WiFi 6 (802.11ax) Tri-Band WiFi (AX6600)
- 2.4GHz AX: 2x2 (Tx/Rx) 1024/256-QAM
20/40MHz, up to 0.6Gbps
- 5GHz AX: 2x2 (Tx/Rx) 1024/256-QAM
20/40/80MHz, up to 1.2Gbps
- 5GHz AX: 4x4 (Tx/Rx) 1024/256-QAM
20/40/80/160MHz, up to 4.8Gbps
- stolnsolJan 15, 2021Star
Well dang. I totally missed the datasheet. Thanks!
