deepsouth06
Apr 07, 2021Tutor
RAX70 Internet dropping
Ok so Yesterday I went out and bought an AX8 - RAX70 (for some reason its not in the available models) and setup it. All working well until this morning where I would notice my MS Teams would for abo...
Christian_R
Apr 14, 2021NETGEAR Employee Retired
Hello deepsouth06,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
JLit
May 02, 2021Initiate
Christian_R it great that you refer people to support within the 90 day support period but can someone post the solution to the problem? I've seen lots of posts but have yet to see a solution or a trouble shooting guide for the problem. Can you post it?
