philc11
Nov 23, 2020Aspirant
rax70 internet speed decreases overnight until reboot
Im using firmware V1.0.1.78 and this is the "latest" today 23Nov20. At reboot, internet upload and download speeds are great ~ 300MBps or more...after a few hours or overnight, we see a drop to 15-2...
Nov 23, 2020Guru - Experienced User
what modem is it connected to?
When the speed is dropping, are you connected to 2.4ghz or 5ghz?
does wired speeds drop as well or just wireless?
philc11
Nov 24, 2020Aspirant
Cable modem model cm1200 connected to the AX6600 (RAX70) wireless router . Wireless speed on both 2.4 and 5 are slow after a period and I cannot directly connect to either the model or router (plugging in an ethernet cable does not work once the speed decreases).
- plemansNov 24, 2020Guru - Experienced User
Are you using wan port aggregation between the RAX and the CM1200?
- philc11Nov 24, 2020Aspirant
I am not sure....the Ethernet Port Aggregation is Enabled (LACP-IEEE 802.3ad) (Port 1 & 2) but the status is "Ethernet Port Aggregation Status: Inactive" . All of this is from the CM1200 http://192.168.100.1 access. The router http://192.168.1.1 controls show
WAN Preference WAN aggregation (1 Gbps + 1 Gbps) - plemansNov 24, 2020Guru - Experienced User
Disable wan port aggregation on both the router and the modem.
The cm1200's port aggregation seemed like it always had issues. its only really a benefit if you have greater than gig service.
Once disabled, reboot the modem and the router. Just have the 1 connection from cm1200 to the router. (port 1 on cm1200).
Don't plug anything else into the cm1200 .
