DrPopper
Jan 15, 2023Tutor
Rax70 router not showing 4804mbs option
My new RAX70 will not show the option for 4804mbs on the 5G-2 band no matter what settings I try it only shows a max of 2401mbs ... new firmware, factory reset, different channels, smart connect on o...
- Jan 16, 2023
I don’t think I can set that to use the lower channels…. I think it’s time to return it.
DrPopper
Jan 15, 2023Tutor
You don't understand the issue ...the Router supports 160 Mhz 4804mbs mode on the 5G-2 band. When logged into the routers UI I cannot select any higher then the 80mhz wide 2401mbs mode on the 5g-2 band .... it's not that the 160/4804 mode is greyed out ...it simply isn't there. It has nothing to do with real world transfer rates ...it's got to do with this Router refusing to go into a mode that it is supposed to supports.
Kitsap
Jan 15, 2023Master
DrPopper wrote:You don't understand the issue ...the Router supports 160 Mhz 4804mbs mode on the 5G-2 band. When logged into the routers UI I cannot select any higher then the 80mhz wide 2401mbs mode on the 5g-2 band .... it's not that the 160/4804 mode is greyed out ...it simply isn't there. It has nothing to do with real world transfer rates ...it's got to do with this Router refusing to go into a mode that it is supposed to supports.
And you are absolutely certain of this fact based on just what exactly?
Are you logged in to the UI with a mobile device or with a real computer and web browser connected to the router via an Ethernet cable?
- DrPopperJan 15, 2023Tutor
Yes I am absolutely certain of these facts based on the specs for the Netgear RAX70 ....I am logged in via Ethernet and a PC ....I have reuploaded manualy the firmware, reset to factory settings, and restarted many times .... same result.
- plemansJan 16, 2023Guru - Experienced User
What region is the router set to?
What channel do you have the other 5ghz band on? Have you checked to ensure you don't have the 2 mixed up (stupid question, I know)?
To use the full 160hz channel width, it has to use the dfs channels. So make sure the other 5ghz band isn't using them.
If you factory reset, what does it show under the defaults for the 5ghz bands? (before you change anything with them)
- DrPopperJan 16, 2023TutorYes it’s on a dfs channel and the other 5 ghz channel is no where near it …
- KitsapJan 16, 2023Master
DrPopper wrote:Yes I am absolutely certain of these facts based on the specs for the Netgear RAX70 ....I am logged in via Ethernet and a PC ....I have reuploaded manualy the firmware, reset to factory settings, and restarted many times .... same result.
Ah yes, your interpretation of the specifications. There are clearly educational deficiencies between your interpretation and fact.
plemans questions reside in the open space between your interpretation and details of your configuration.
- FURRYe38Jan 16, 2023Guru - Experienced User
I like to review the spec sheet for details of what is what:
https://www.netgear.com/images/datasheet/networking/wifirouter/RAX70.pdf
