Rdp_75
Oct 06, 2023Follower
RAX70 Security assignment of WPA3
My router is RAX70. My LAN is working on wire and WiFi. When I assign WPA3 security, 2 of my wireless devices do not support WPA3 (devices will not update to WPA3).
Is it possible to assign WPA2 on guest wifi, and assign WPA3 to the primary WiFi.
I did assign this, but the devices would not connect on the Main or Guest WiFi.
Please help with problem.
1 Reply
Does the RAX70 have mixed mode WPA2/WPA3? If not you'll need to use WPA2 and AES only on the router.
