airassaultbob
Jun 02, 2021Follower
RAX70 smart connect
When in settings and enabling the smart connect feature, all appliances on the wifi disconnect and will not re-connect even when manually attempting to do so
Christian_R
Jun 07, 2021NETGEAR Employee Retired
Hello airassaultbob,
May you check to see if your router is due for a firmware update. May you also try a different web browser to enable smart connect.
Christian
